Hi, I was wondering if anyone here could help me out on my problem. My keyless entry remotes stopped working (both of them at the same time). I checked my owners manual and found the procedure to relearn them. From the info center I scroll over to PRESS "CHECK MARK" TO RELEARN REMOTE when I press the "check mark" which is set/reset, the manual says that it should display a message that the programming is active. I never receive this and can't continue because of this. It's like the car will not go into programming mode. Any help would be greatly appreciated. Thanks in advance.
