ok look the motor mounts are not riped or torned or broken but i think that the motor moves a bit more than it supose to like when accelerate fast or when i change from park to drive or reverse or they dont neccerly have to be ripped to be bad ????
Have someone get in the car while you watch the engine with the hood open. Have them put the car in reverse, and torque it up against the brakes. Then do the same in drive.
If you think it's too much movement, it likely is. Double check the bushings in the dogbones on the front of the motor, these are a common failure, and a fairly cheap fix.
HTH!
