Kickdown linkage question
What is it that you're looking for in the picture? I have a 1961 and 1963 Impala Shop Manual, which has some pretty good diagrams, but I'll haveto send those on Monday (3/9/09), since my scanner at home is crap.
Here's what I know:
There are three linkages that actually make the assembly up; one adjustable linkage that goes from the left side of the carb to the second linkage that actually mounts to the top left side of the bell housing. From here, the third linkage attaches to the fixed linkage and the tab/linkage on the tranny (there's a small tab above the forward driver's side corner of the fluid pan with a small ball-joint-like fitting on it).
Even though I couldn't scan the diagram that I know will help, I hope this helps out a bit.
