Does the 07 LT have a stock powersteering cooler my fluid has turned orange and is bubbling
before i go flushing the fluid and possibly changing the pump i want to make sure there isn't a seperate underlying issue
Look through the radiator grill inlet. Most 8th generation Impala models had a power steering fluid cooler line that was attached in front of the a/c condenser. The cooler was simply a silver aluminum line (sort of a flat oval shape) - with no cooling fins. It is very obvious when you look for it.
