No brakes involved with the SS... just turn TC off and floor it... if you actually get traction and dont leave a burnout, then your tires are probablly new, and you shouldnt be burning out anyway LOL.haha that's crazy talk....sticks are clearly the easiest....stomp the gas then dump the clutch! I think there's way more finesse to getting the gas pedal to brake pedal ratio on the auto correct..
Things I liked best about that video....tims smokey burnout!!! - YouTube
heres my buddy Timmy on his 06 NightTrain.. It was time to replace the rear tire so he said WTH. he wanted to shift up but if he took his foot off the ground the bike would have kicked out.
oh, good to know, I will keep that in mind, thanks..No brakes involved with the SS... just turn TC off and floor it... if you actually get traction and dont leave a burnout, then your tires are probablly new, and you shouldnt be burning out anyway LOL.
See, I'm looking for the big smokey burnouts like the one I posted, anything less just leaves me feeling empty inside lol..With an 8th gen SS, even with brand new tires, if you don't get a burnout from a standstill, something is seriously wrong. I can do a short burnout on dry pavement starting at 20 MPH. No performance mods, good tires.
I've seen ads for a "burn out button" which when installed and pressed, cuts off brake fluid pressure to the rear, so when you hold the brakes, you can burn out all day long and never worry....this should be a mandatory mod....I want one on everything I own!!
You should definitley install that on the Impala. I just want to be able to see your face when you realize you cut off brake pressure to the wrong wheels LOL.I've seen ads for a "burn out button" which when installed and pressed, cuts off brake fluid pressure to the rear, so when you hold the brakes, you can burn out all day long and never worry....this should be a mandatory mod....I want one on everything I own!!
Pull the e-brake??????You should definitley install that on the Impala. I just want to be able to see your face when you realize you cut off brake pressure to the wrong wheels LOL.
Honestly tho... i wonder if it would even work if you cut off brake pressure to the front wheels instead... doubt the rear brakes are even powerful enough to hold.
e brake will DEFINITLEY not hold the car when u floor it... and that would defeat the purpose of having the burnout button anyways...Pull the e-brake??????
Ill have to go home and see if i can get my video of my burnout in my 93 Caprice....I also have a few from the Dream Cruise ill post up....If somebody can post a better burnout video, id be shocked![]()
hahaha, that would be funny to see! well it's not specific to any application, so if you have FWD, you can set it up to cut off the front wheels, and if you have RWD, you can set it up to cut off the rear wheels, but you are right, the B-Body's have that brake issue....I just assumed everyone did that mod to fix them...You should definitley install that on the Impala. I just want to be able to see your face when you realize you cut off brake pressure to the wrong wheels LOL.
I feel like that's a challenge :beer:Pull the e-brake??????
what year impala do you own?hahaha, that would be funny to see! well it's not specific to any application, so if you have FWD, you can set it up to cut off the front wheels, and if you have RWD, you can set it up to cut off the rear wheels, but you are right, the B-Body's have that brake issue....I just assumed everyone did that mod to fix them...
