It depends on how you apply the plastidip. If you go very lightly with it every time you apply it, expect to do at least 5-6 coats. But if you go somewhat heavy on the plastidip the first few times, you won't need to do that many coats. But the correct way to apply plastidip is to spray it lightly and mist it over the object and give it 5-10 minutes to air dry then mist over it again with a 2nd coat and etc. The reason I had to do so many coats was because I could still see the chrome trim after 3ish coats. The completed project turned out like this:Thinking of using plastidip. How many coats is recommended?
That looks great! I love those headlights, too.It depends on how you apply the plastidip. If you go very lightly with it every time you apply it, expect to do at least 5-6 coats. But if you go somewhat heavy on the plastidip the first few times, you won't need to do that many coats. But the correct way to apply plastidip is to spray it lightly and mist it over the object and give it 5-10 minutes to air dry then mist over it again with a 2nd coat and etc. The reason I had to do so many coats was because I could still see the chrome trim after 3ish coats. The completed project turned out like this:
https://goo.gl/photos/bPpWR92SjThSNsaMA
https://goo.gl/photos/9ht5prGYPCqNZo9z9
