P0442
1 reading
29K views 16 replies 10 participants last post by  hatzie
#1 ·
P0442- Small EVAP Leak Detected
Anybody actually take their vehicle in for a smoke test and successfully found their issue with this code?
I replaced all major components that usually fail and cause this code a few weeks ago, cleared the code with scanner and it would come back in about a week or two.
Just wondering if anyone else has also replaced the Vent Purge valve, solenoid, and gas cap but still have the code come back and what was the ultimate fix?(I also cleaned the heck out of the gas cap filler area)
:beer:
#5 ·
Yep that's what I'm thinking, I just wanted to check here first to see if anyone else has had the same luck that I've had with this pesky code.
on my 2010 the evap canister within drivers rear quarter panel fixed my evap error code ( i don't know the number off the top of my head but you didn't reference the canister in your original post so i thought i would). the evap module on top of the motor did not resolve the issue initially.
Yep I've replaced that evap canister too a few weeks ago along with the evap module on top of the motor, at the time of my post I couldn't think of the correct name. I think this is the third evap canister I've bought in the last 3 or 4 years trying to fix this issue LOL.
Im dealt with that on my 2012 LTZ. I changed the front 3 spark plugs and everything was fine, then I changed the rear 3 and got a rough idle and that P04442 error. I replaced the Vapor Canister Purge Valve / Solenoid with ACDELCO 12610560 and it came right back, so I cleared the codes again disconnected the battery and the code went away, but still have a rougher idle since changing the rear 3 plugs.
That's the same canister I bought a few weeks back. Kinda stumped, here. Don't really want to take it to a shop for a smoke test but that's looking like my only option unless anyone else has any other pointers on what could be causing it?
I was really wondering if anyone else had taken their car in for a smoke test for this particular code and what was the cause?
#4 ·
#11 · (Edited)
Log some tank pressure data and take a look in this thread for leaking and properly operating evap system pressures.
If you aren't getting tank pressure readings like the above thread then the tank pressure sensor has failed.
If you're seeing changing tank pressure changes then hook it to the smoke machine.
You can DIY a smoke machine and use Baby oil for the smoke. You can buy the bladder to plug into the intake or the filler neck.
#12 ·
FWIW my brand new supposedly correct and well reviewed aftermarket gas cap for my '11 Impala just does not feel right when clicking in, not positive. Gasket looks good. I got the code P0442 and had an old cap with a worn gasket so I replaced with this. I have seen a lot of comments that sometimes the aftermarket caps just don't seal well. Mine is still throwing the code every week or 3 but I just adjust the cap and clear it cause I'm not particularly worried about that code. Will try an OEM cap or maybe an extra little gasket on top of the one in the aftermarket cap. YMMV. Seif.
#14 · (Edited)
You can make a DIY EVAP smoker;
You need an air compressor you can regulate the output down to 2PSI or so or a bicycle pump.
Fairly elegant smoke machine. Probably costs around $20-$25 in parts.
Really ghetto but it'll work. This is a glass jar so care must be exercised to keep from needing to clean glass shards off the shop floor.
Here's how to smoke the EVAP system with any smoke machine. The Ready Smoke is sexy as hell but it ain't cheap.
Notice how he uses the laser pointer.
