Outside air temp is all dashes
4.9K views 4 replies 3 participants last post by  hatzie
#1 ·
I have a 2014 Impala limited. My ambient air temperature display is all dashes. Replaced the sensor, tried the A/C and RECIRCULATE button press but no luck. Any ideas?
#2 ·
The ambient air sensor display takes so many minutes of driving to reset it and display the temperature. Did you drive the vehicle to see if the display changes to the correct temperature? The information is contained in the vehicle owner’s manual.
Did you buy a GM sensor?
Did you inspect the wiring harness connector for corrosion?
GM sells an ambient air temperature connector pigtail, which would enable you to replace the connector (and not the entire harness).
If the display does not reset after a drive, I would suggest checking the existing connector. It may be too corroded to clean with contact cleaner, and you may want to replace it.
