this what they seed
Thanks for the pictures of your Chevy Impala.
I have seen that type of antenna base before, and unfortunately, although our shark fin can cover the base without an issue, we have some problems attaching our antenna to your antenna base.
The problem lies in the short stubby antenna that is on your vehicle, when you remove it, you'll find it is attached via a clip-type connection, whereas our shark fin was designed for antenna bases that use screw threads to attach the antenna.
However, you can still use our shark fin to cover the antenna base, but the antenna will only be functional if you are willing to perform some modifications to either our antenna on your antenna base to make it work.
We do have Switchblade Silver Metallic / Wa636R (17U) available.
