Alright here it goes, driving and check engine light comes on and im like obviously WTF any ways i needed to fill up almost dead on e so i figured fill it up and see what happens. Still check engine light on trans is slipping and staying one gear. car was running fine on the highway so i would say unlikely the trans took a crap. But here are all the codes this is the riddle from hell.
codes in order of recieved.
84 Downshift feedback (multiple DTC's)
83 Torque Converter QDM (quad driver module)
82 Shift control Solenoid A (multiple DTC's)
81 Shift control Solenoid B (mu;tiple DTC's)
27 EGR electrical fault QDM (quad driver module)
26 EVAP purge control circuit failure
48 Mass air flow System failure
29 Secondary Airpump Injection circuit- Possible lead no air pump anymore(how do i disable?)
90 TCC enable Fault QDM (quad driver module)
Transmission Codes
34 Map Sensor
53 System voltage too high (perhaps a big one "original alternator") (multiple DTC's)
52 ECM prom error ( Possible ECM failure)
72 Trans output Speed sensor
28 trans Pressure Switch Manifold Problem.
for god sakes help man this is pissing me off
Transmission Codes
34 Map Sensor
