1 - 9 of 9 Posts
i have a 1993 camaro z-28 lt1 motor i took it to get it smoged and they told me it didnt pass cause of alot of fumes what can the probleme be?
You should have gotten a printed read-out of the test results that would point you in the right direction. Maybe a COMPLETE tune-up on a 14 YO car would be in order?
CoCo, it may need a "tune up" New plugs,plug wires,pvc valve,air cleaner,oil changeand filter. Do you have a 'Check Engine'light on? This could diagnose a need for an EGR module / sensor or an oxygen sensor(s) . Also , a problem with a having a car tested for emmision is it doensn't have time to warm up enough. Ya might try taking it for a 30-50 mi ride up and down the interstate or 2 lane to get it warmed up enough o pass cause a cold engine will emit more emmisions than a 'warm / hot engine will
A lot of high milege engines have worn piston rings, that would be my first guess.........
they should have told you what it might be is so many things if he was any kind of a smog guy he would have... take it somewhere else and have it check tell them what you are wanting to do could be it needs a tune up but could be any of a few parts most of the time its a tune up
you,ll have to get the computer scanned on it to see if it has any trouble codes in it,this can cause it to fail,that means its running too rich,it could be an 0-2 sensor,causing this,but have it scanned to be sure,then you,ll know,good luck with it.
too many to list if your local shop did diagnostic to tell you it didn't pass they should be able to tell you what failed?
Discussion Starter · #8 ·
Check out the OXYGEN (O2) SENSOR OPERATION AND TESTING over @ the (first) link below.
Plus, there is a way to read the codes listed in these link w/o havin a scanner. If, you want to go that route. Or just run it down to the local AutoZone or Advanced Auto and they will read the code for you.
Good luck!
Discussion Starter · #9 ·
The only way that car would become smog legal would be to replace the engine.
Trust me...it's cheaper this way.
1 - 9 of 9 Posts
