1 - 15 of 15 Posts
Probably lots of discussion but wondering what everyone is using re: oil for 2011 and up with Dexos rating. I do my own now and use PF 63 AC filters. I have used Pennzoil conventional for years in my 02 but I"m not sure about running it it my 2012 ? :dizzy:
Back in Black
dealer does mine for free for 2 years, so dexos and oem filter
I did read where if GM can prove it was a lubrication failure using oil without the Dexos 1 rating they could refuse warranty.
From the 2011 impala owner's manual under Vehicle Care pages 10-9
Selecting the Right Engine Oil
Selecting the right engine oil
depends on both the proper oil
specification and viscosity grade:
Specification
Use and ask for engine oils with
the dexos
certification mark.
Oils meeting the requirements of
the vehicle should have the dexos
certification mark on the container.
This certification mark indicates that
the oil has been approved to the
dexos specification.
This vehicle was filled at the factory
with dexos
approved engine oil.
Notice:
Use only engine oil
that is approved to the dexos
specification or an equivalent
engine oil of the appropriate
viscosity grade. Engine
oils approved to the dexos
specification will show the
dexos symbol on the container.
Failure to use the recommended
engine oil or equivalent can
result in engine damage not
covered by the vehicle warranty.
If you are unsure whether the
oil is approved to the dexos
specification, ask your service
provider.
Use of Substitute Engine Oils if
dexos is unavailable: In the event
that dexos
approved engine oil is
not available at an oil change or
for maintaining proper oil level,
you may use substitute engine oil
displaying the API Starburst symbol
and of SAE 5W-30 viscosity grade.
That only applies to direct injection engines, which so far only the 2012 and 2013 have. Any previous model impala can use any conventional 5-30. '12 and up require Dexos rated oil.
2011 owner's manual " says" dexos or you may use substitute engine oil
displaying the API Starburst symbol and of SAE 5W-30 viscosity grade.
Designated Driver
My '11 requires it.
Back in Black
thats funny same motor as the 2010 but the 2011 needs dexos what a scam
sounds like the same argument as dex3and dex6 GM comanded it :devil:
Back in Black
oh lord im getting outta here before the ban hammer gets dropped.:dizzy:
Oh yea :devil::devil::devil:
the devil made me do it:yikes:
Its ok, 5 second rule!
The difference as I see it, is that the transmissions may not have changed, but they have been plagued with problems, so I can accept a new fluid requirement standard. But the engines have never had a problem, so I can see no justification for a new oil standard requirement for the same engine.
Just an fyi, I use Valvoline Durablend in my 2001 monte carlo and 2007 Impala. It meets or exceeds the 'dexos' standards of GM but it doesn't say that on the bottle. I found the information on their website, they will not pay the licensing fee GM charges to allow them to use the dexos name.
When I got the 2007 I called GM and they said since Valvoline Durablend was tested using GM approved methods it would not have any impact on the warranty.
I always use Amsoil on all my cars. Haven't started using it on my SS since I've only had it for about 6 months and its been stored for 4 LOOL
1 - 15 of 15 Posts
