1 - 20 of 22 Posts
Ok, this question may rate right up there with the type of oil to use. I am wandering if to use the Purolater Pure-One versus the AC/Delco oil filter for my 2011 impala LT, 3.5 L. ? I saw in a parts book/computer screen at advance auto, that the AC/Delco part # is PF61 and also lists a PF61e ? Any ideas on the two different #'s for this filter from AC/Delco. I read somewhere that I should stay with OE for the oil filter and that would be the AC/Delco ? I have been using the Pure-One without any noticable problems. Of course price is also a concern since Pure-one at my local Advance Auto is $2 higher than the AC/Delco.... Thanks for the help..:10:
Every 2nd Matters
I use Ac Delco when I can, Fram otherwise.
I would go with the pur-one filter. Thats the one they use when they have a sale on oil (by 5qts and a pur-one filter for like 25$). Thats what made me switch.
"e" is for e-core. Look at the face of the 61e filter, looks much cheaper made than the older AC Delco filters. I am switching to Purolator Pure-One when I use up my last CPO dealership oil changes. I already have 2 Pure-Ones in my arsenal for this car.
I usually go with the Fram synthetic.
i have used fram in the past. Till i looked a the wix and fram cutaway filters side by side and filter spec and filteration # and thats all it took for my choice. WIX hands down. I wort to hard for my money and have to much respect for the engines to run any less of a filter.
Purolator and Wix are great choices, the dealership oil filter will work fine too. Avoid the cheapest Fram
An addition to my "wix" in everything posting
I am servicing/rebuilding the fuel system on a diesel engine that I have. The diesel injection service center that I have been dealing with are recommending Baldwin fuel filter over the Donaldson and Wix filters that I have been using. I have since done some research on Baldwin filters and they have some pretty good stats.
I will try one on the Impala for the next oil change.
They are comparative in price to the wix and in some cases show better numbers for efficiency.
Baldwin Filters | Product Highlights
FWIW
Paul
WIX fan for years, never heard of Baldwin, but looks impressive.
Baldwin has been one of the favorites for the heavy duty fleets for a long time, same as Donaldson
I have heard nothing but, positive things about the wix. But, most "deals" at auto parts stores include a "puralator one" filter which, I have been using for a while now. It seems of decent quality. I usually get 5+ qrt jug of valvoline high mileage or castrol gtx with filter for $30-35. Note: 7th gen 3.8's take 4.5qrts. I have been recently poring in 3.5qrts and a quart of lucas oil stop leak due to an lim/valve cover leak. Once I have the top end rebuilt I plan to start using Lucas Oil Stabilizer and will do the same process. This will help clean out the sludge and keep good lubrication. I have always been a fan of lucas products :eek:k3: My buddy has been running the oil stabilizer for quite some time in his 4.0 jeep and keeps crystal clear oil for some time now.
Every vehicle I have ever had new, never have had leaks. Amazing what proper maintenance does.
Dogstang,
I'm betting that Purolator and the GM Delco filters are the same. Since GM doesn't make oil filters anyway and Purolator does most likely they are identical in nature. Get which every is the cheapest unless your car is still under warranty and then you should stay with the GM Delco version.
Durango
Wix FTW!!! your engine will thank you...
Dogstang,
Durango
Fortunally I have not found an e-core Purolator oil filter....yet :hope:
Bobistheoilguy had a good writeup on oil filters and who makes what years ago. I stay away from Fram and crappy-ass Advance auto parts generic brand.
beast50,
I frequent Bobistheoilguy website too and that forum has educated me allot regarding oil, filters and such. I highly suggest anyone with the same questions to take a look see at this site too.:eek:k3:
Durango
Have bought Wix filters for years bought one at local auto store its made in China. Guess I will stay with OEM made in Detroit.
It looks like both Canada and the United States have managed to export a lot of manufacturing - and manufacturing jobs - to China.
1 - 20 of 22 Posts
