Excuse me, I got two years and 40k on those pinnacle power stops.
Cop pads are the same size. 1159 front/999 rear. Maybe semi-metallic (cop) vs ceramic (non-cop). Cop front rotors are larger (323mm vs 303mm). Front calipers are different too.Another question is will the cop pads fit the non cop calipers and if so will they have more pad surface contact on the non cop rotors.
Rear rotors are the same. To swap over to police/taxi set-up, you need police front rotors/calipers. And, if iirc, 17" or 18" wheels for clearance.Are the rear rotors larger also?
Lol, I've got the original rotors on my '12/'13. They both have 70k+ mi. On the son's '16 Limited (150k+ mi), I replaced all 4 with a Detroit Axle set from Ebay Motors. When the '12/'13 need rotors, they'll get the cheapest (closeout) rotors from Rockauto. My mantra is cheap rotors/quality pads.Thank you for that Sheila 😊
Do you run oe or aftermarket rotors on yours?
What kind of mileage do you get from a front set of rotors?
