Had to do some brain surgery on my Gen-7 BCM transplanting the original 9C3 spec processor to a new BCM board. Reason for this is only a generic flash program is available for the replacement BCM. I smoked the original BCM with a 100 watt VHF 2-way that had a loose mini-UHF connection pumping the energy up the OnStar data line so with no replacement I had to get medieval and break out the stereo microscope and swap the actual processor around. Results? Everything is working once again. I attached some pictures for your entertainment.
