2002 Impala was t crank want start no power to fuel pump no power to I injectors radio stopped working I hooked the test light to. Battery tested
for short found it the Bcm cluster fuse was the bad guy so how do I fix this problem I read a. Forum that said cut the two purple wires behind the obd11 reader plug but my 2002 only has 1 purple wires so wat color is the other wire can some one help me?
