i just got a 94 caprice with 200,000 miles on it and after installing an aftermarket cd player the cluster(speedo) stopped working.i did all the fuse checking,wire chasing,and stuff.also can you swap out a standard gauge in place of the digital one.i saw something about a "z28 swap",i would rather have an ss or other.ok the next problem may be an easy fix not sure though,the car runs fine except when i go up steep hills the car starts to "chug-stutter-hesitate-then take off "im thinking its trash or dirt in the tank.i was just wondering if anyone else had the same problem.thanks
ok first things first after 200000 the caprice fuel pump is gonna go out soon i bought my 1st caprice w 220 + thousand on it and the guy i bought it from didnt know why it wouldnt start i also bought it because it was a 5.7 and not the shittty 5.0 motor ......... anyways after a $60 or so fuel pump from checkers or wherever my car started fine and ran like a champ........
i would suggest replacing the fuel pump it really only takes about an hour or two if ur inclined enough to do so id also check the tank for rust , debrie etc and lets us know how it goes good luck :biggrin:
X2 on the fuel pump, and remember to grab a new fuel filter while you're at it, it's just better to make sure ya don't get any gunk plugging it up either...also, probably wouldn't hurt to do a decent tune up, plugs, wires, air filter, tranny flush and filter as well.
If you still have the hesitation/low power, throw a code reader on it..
I've got the 4.3 in mine, and going up really steep hills, it kicks down a gear, but otherwise has decent cruising power, never have driven one with the bigger V8's...yet...:wink:
