Hi folks....Bad shake in steering wheel when braking hard at high speed. Changed rotors and pads. Still the same. A bit of play on passengers side hub. Probably the hub. Have 1 on order. Struts are pretty soft. Possible struts being weak causing the problem under heavy braking or probably the front hub? Thanks
My guess would be the hub. Although, I must say, I've never had a hub issues on any of my previous cars, so I can't say for sure. But it sounds more likely than a strut. For me, replacing the rotors and pads has always fixed it.
Did you replace both front and back?
Just changed the front. The back were in great shape. Its definitely in the front causing the problem.
