okay i got an 04ss , it was givin to me by my pop's with 25000 miles. i noticed that when i turn , i get a binding sound in my steering wheel when im making a turn from a dead stop. any ideas???? ..................................
o an also my climate control on the driver side only will blow a/c no heater , while the passenger side will blow both hot and cold. please help i wanna get the kinks worked out before i slap my new m90 super charger!!! :cool:
On steering problem I do not have a suggestion other than check the steering fluid level, it could be low.
On the heater/AC there is a blend door control, which you use to temp for each side, most likely the controller is clogged or the vacuum line from it or at the blend door connection is disconnected. Look behind the heater control and under the dash to find which it is.
