installed new head gaskets on the lt1 350 (1994 trans am) 5.7 and i did have the heads resurfaced the car was running fine but it was overheating (head gasket was leaking water to the piston...) so anyways isntalled niew gaskets and cleaned the intake manifold, is there a bleeding proceess or somthing that i may have over looked? timig is correct as i did mark them seprtly and its also marked on the cable and tip itself so that fine. fuel pump seems to be working upon ignition turn...and spark plus are new and the car does have gas. maf sensors all installed correctly.
