It depends, is it the module or a sensor? If it's just the electronic sensor that is causing it you can safely ignore it. Are you having engine or starting problems, lights that don't work etc,? If not just ignore it.
A new module itself costs about $200.00 including labor, if it's a sensor the module won't fix the problem and some sensors are very expensive to replace because of the labor involved.
