1 - 9 of 9 Posts
Is the Monte Carlo SS cluster compatable with the impala setup?
will all 6 Gauges work correctly?
it's the same as the impala SS cluster but "battery" instead of "boost"
Yes it is, one of the best upgrades for the gaugeless impys.
There seems to be conflicting answers on here about these cluster upgrade. You guys say all gauges will work while others say oil pressure won't. So, what is it?
If you have the 3.8 it'll work if you have the 3.4 you have to swap to the 3.8 oil pressure sensor.
Gotcha
Well, I might just have to pick one up sometime from the yard then. But, it would still require a dealer to correct the odometer.
Gotcha
I still haven't corrected mine the dealers around here didn't even know what I was talking about when I tried asking them about it.
Yikes that would scare me a little bit. I wouldn't mind if it stated lower than my actual miles:giggle: But, I would still find out the difference of each cluster and keep in mind of it.
1 - 9 of 9 Posts
