Anyone put a Magnaflow Cat on a 04 impala ss? If so, give me some feed back please. I am interested in purchasing one....
i dont have an SS, but i have that cat on my 00 base model and i can tell you that it might not happen immediately, but you are going to see a check engine light.the only way to get rid of it is to have it deleted from the PCM with a tuner. it will be code PO420. i was beginning to think it was an urban legend until a year and a half later when mine showed up.
Do you notice any noise difference? If so, a lot, little? Anything performance wise?
Was it the Magnaflow #23405 model causing the check engine light issue?
I have an 04 Imapla SS (Indy Edition). The mass air flow regulator went bad, and I had it replaced. Now my Cat is causing the check engine light to come on. I believe it burnt out due to the MAF issue. I see Magnaflow have two CATs for my vehicle (#23405 @ $483.03, and #46405 @ $1532.80). I just a deal on the #46405 for $399.95. Now I worry that I'll have the same check engine light issue. Does anyone have feedback regarding the differences between the two models?
