1 - 20 of 41 Posts
Anyone lower their newer impala? What springs did you use? How many inches was the drop and was a camber kit installed?
Before I decided to air ride my impala I was looking into buying a set of lowering springs from neuspeed. I believe you can get up to a 2" drop out of them. That just wasn't low enough for me though:biggrin: As far as the camber kit, I wouldn't think you would need it. The camber in the rear even with the air ride doesn't wear the tires bad at all.
I went with Eibach and it lowered it about 1.4"front 1.6"rear and they didnt make the ride real stiff, look in my garage and you can see a pic of it, and i did not have to install the camer kit
Jon
04 SS
65 SS convt 396
SS model springs will give you the smallest drop possible. Eibach also makes springs, as do a few other companies.
How much drop are you looking for?
I have heard only good things about the eibach and kyb strut/shock combo with w-bodies. I plan on installing the eibach and kyb combo on my impala. From my monte carlo club, I found this was a very popular choice because they are good products.
Also, i was at my local AutoZone, and i saw a kit for lowering this generation of impala for like 20$, i didnt get to look at it much because i was in a rush, but it looked pretty legit.
It said it will lower or raise the car up to 4 inches either direction. Im not sure if its reliable or a great deal, so dont hold me accountable lol
im goin too get vogtlands springs with KYB AGX's.. i read alot of good stuff about that setup!
hey im looking into lowering my impala also, could you link me up to the setup your running, i am a noob to this suspension so i am somewhat daft to what i need.
Also, should a get lowering shocks, like the kyb agx's? or eibach springs with stock shocks?
im looking for about a 2 inch drop maybe more, ride comfortability doesnt matter to me i don't drive the car hard or on a track or anything
four lowering springs. the ride is a little harsh, according to some, so i ordered the SSC springs from ZZPerformance.com, but they failed to tell me they were out of stock. so i cancelled my order and just bought the Canuck Motorsports off ebay, which are the exact same thing as the SSC springs, just under a different brand name. same drop height and same part number. was right around $200 shipped.
got them installed about a week ago and finally got the new tires on and aligned. when you lower it, i recommend the anti-pogo washers. i have them installed and the ride quality is just fine. see my thread i just started for pics.
Jon
04 SS
65 SS convt 396
I was looking through your garage and I didn't see any pictures of the ride lowered, can you post some pictures in here?
Can't I just chop my stock springs?
I have an 05 Impala SS and I want to lower the rear a little to level the car out. Will chopping an inch out of the stock springs ruin them? I did this on my Harley but I took out 3 inches and killed the ride. I looks good down in the weeds but its a back breaker now!. I don't want to kill the ride on the car cause it is pretty f'n smooth
1 - 20 of 41 Posts
