I bought an '03 Impala LS about a year ago, and it already had a lot of miles on it. However, I drive a lot, so I have put several more on it since then. With the miles building up, I'm planning on putting an aftermarket engine in it. I want one with a lot more take-off and speed to it.
The car is an automatic, not to mention front-wheel drive, so I don't know exactly what I can do. Has anyone seen an aftermarket engine that would fit and give me some speed and take-off? Noticeable more-so than the stock one did.
You want to be careful with switching the engine, if youre looking for more speed and take off my advice would to be get the same engine that was already in your impala (3.8 or 3.4) and look at a turbo charger. If you move to a larger engine you can easily run into tons of head aches with wiring.
Stay with the engine you have, just get or have yours rebuilt. It would be very hard with the electronics and computers to change to a larger faster engine. If you have the 3400 series you might check into installing the 3800 series. See if any one else has done this. Then check into other performance enhancements that you can add to your engine.
Swapping motors period is a PITA. You've got to deal with a mess of computer programming/tuning, hardware swaps, and the labor/downtime involved with it all.
You have the 3800 motor, so a topswap would be a good option for you, and leaves plenty of potential for a reasonable amount of money.
Member 04DetroitLS has plenty of knowledge on this subject.
Alternatively to having any headaches associated with modifying vehicles, you could trade in the LS and try to pick up a lower-milage Impala SS. The 04-05 Impala SS models have 40 more horsepower stock than your 03 LS has.
we did a topswap in a weekend, it wasnt all that bad
If you're worried about milage grab a 06 Buick Lucerne engine (3800) w/ lower miles, use your oil pan and swap away, while its out you could do heads/cam or topswa/cam or rockers, etc... any number of things. This would allow you to drive your imp while building an engine for least amount of downtime. If you shop correctly, you can grab the L26 for ~$600-800 as opposed to a $3000+ "race block", and any non 3800 swap will cost more than that
