1992 Olds CC Wagon. 5.7L
The CHMSL does not work nor will it without replacing the glass and latch on the gate.
From my readings this corresponds to a cruise control failure. Where can I test the cruise control to make sure that it is in working order short of the problems back there?
I have been told I believe here and else where that I should chase the wires back and solder in some resistors. What size resistor would be needed? I should be able to find the wires in the driver side wheel well and cut them there and put in the resistor between the two wires correct?
