Hey guys,
I've always loved Impalas and just recently moved to North America and found myself buying one. This forum has been a great help with understanding the car and fixing some issues I've had. So far I've had the issue where the wiring harness connected to the shifter broke, so I couldn't remove the key from the ignition, and I've also had the rear demister fail because of the harness near the interior fuse box. Both have been quick fixes based on info I found here.
I'm struggling with an issue at the moment. I want to retrofit LED bulbs in the front turn signals and the rear brake/turn lights. To prevent the hyperflash, I need load resistors. So far I've tried two different harnesses that had 3157 bulb sockets, so one end of the harness plugs into the car's bulb socket, and the other end fits into the headlight housing, with resistors in between. They both had the same issue- they work perfectly except the turn signal is not bright enough. So when the parking light is on, and you turn on the turn signal, the flashing is so dim that you can only tell it's flashing if you look very closely. So it's useless as it basically means the turn signal doesn't work at all.
Since both harnesses did the same thing, I tried just wiring a load resistor into the car's existing harness. I wired a resistor between the turn signal wire and the ground. That had the same issue, where the turn signal was not flashing bright enough to be noticeable above the constant parking light.
I'll also mention that when plugging the LED bulb straight into the car's socket, the bulb works perfectly. It's very bright when running the turn signal, and is exactly what I was looking for, except the fact that it hyper-flashes.
So I was hoping someone has some experience retrofitting LEDs and found a way around this problem? I don't want to replace the headlight and taillight housings with LED ones as that's quite a lot of money to spend simply to have LED lights. The only alternative I can think of would be a 'switchback' LED bulb which glows white for the parking light and switches to amber when the turn signal comes on, but I'd like to avoid that if possible to keep the amber parking lights.
Thanks in advance for any help or advise guys!
