Im installing a L76 block(similar to ls2)into my 1996 caprice. wanted to know will my lt1 accessory setup - bolt on to the l76 block or do they sale a bracket kit that will located my alternator/compressor/and p/s back in its original location with the water pump pulley setup.
Think you can use "truck accessories" in the b-body if you have engine mounts that keep it low. Can't imagine the LT1 stuff fitting.
Years ago I began an LQ4 swap on my 1996 Caprice and life happened and that stalled, car has sat in pieces for 8 years since, I need to purge it from the garage. Ran 11.5 as a true street/strip car with the LT1.
