1 - 14 of 14 Posts
My dad (is a police officer) and just got a 2008 Impala from his department. As of today we just got black/silver rims and limo tint. He has had a Grand Marquis for the past couple years, and I know nothing about Chevy's unfortunately. When I get back home to check it out I plan on debadging and plasti'diping a few parts.
Can you guys give me some insight on what else can be done to these vehicles. All I've seen on eBay is the "chrome" grilles, door handles, etc. and 24" wheels on YouTube lol.
This is going to be his police take home vehicle and is equipped with police lighting.
Specifically have you guys experimented with the chrome trim on the trunk, I personally don't like it although I guess it flows with the taillights. (which I want to smoke out)
Also can I remove the chevy bow tie on the trunk lid, or will there be holes exposed, etc.?
· 8th Gen Antagonist
All the badges come off with no holes, they are just stuck on. The chrome strip can be painted to match, or plasti-dipped. There are a few aftermarket headlight options, a few different grilles, not a lot in the way of customizing parts, but look around at other members rides, there is a lot you can do. Anyway, welcome!
Oh, that's great news on the rear bow tie. I will just remove it then.
I am not a fan of the aftermarket headlights, how bad is the glare with an HID kit in the OEM lights? Assuming I lower the aim of them a bit.
Any maintenance or mechanical issues I should be aware of. This one has about 85k miles.
I think I plan on plasti-dipping the front bowtie, the chrome around the grilles, and maybe the foglight housings if they aren't 'black' enough for the look I'm going for.
Also remove all rear badges and the impala side emblems.
· OEM LOL
Problems are
Transmissions are made out of glass
Blend door actuators
Door lock actuators
Rear defroster burning up
Remote fob receiver only working from 10ft away
Intermediate steering shaft
Rack and pinion
That's just some of the common problems
Personal opinion, the glare in any Oem halogen housing is pretty bad and hids shouldn't be in them.
Never flush the trans just drop the pan and change the filter and fill it back up every 30k miles
Aftermarket trans cooler from a police car (which you prolly have since you have a police car) will prolong the life of the trans.
That's most of them but I'm sure I'm forgetting a couple things.
Like said above all emblems are stuck on no holes
Chrome strip is just held in with clips it's just chrome plastic
Look around on eBay for headlights, there are a few different styles. You need projectors for HID's to work properly.
Don't forget EVAP canister purge valve and solenoids in the problem list.
· Banned
Problems are
sorry for hijacking... but that's what she said :eek:k3: ...
Seriously why is Flushing system bad... i am worried because i got a car that was flushed few months back... :WTF:
flushing the transmission fluid isn't bad, it's just that its not nearly as effective. when you take the pan down cleaning all the soot from the pan and especially the magnet and replacing the filter ensures that no clutch material is left inside. flushes do not carry away that stuff. i just serviced mine for the first time this way at 44,000 miles and looked like the fluid was nice and red but still had that black soot which had to be removed.
· Premium Member
Lugs, you go ahead and flush your transmission. Nobody else do it though.
It IS correlated to failures in these particular transmissions. I would not say that transmission flushes generally are always bad, but these transmissions are made out of glass and toothpicks and the flush in this particular application makes them even worse. The flush is not the primary cause of failure - the crappy transmission is the cause of failure. Several cases exist where it seem to speed up the failure though.
1 - 14 of 14 Posts
