1 - 12 of 12 Posts
I just received my Jacfab spacers for my Impala. Wondering if there is a write up anywhere on here that I may be missing? Installation looks pretty straight forward. I'm curious as ot what I should be tightening the bolts down to? Also looking for any other information I may need prior to the install.
Well I tried to pop it off. It's on there pretty good. Thinking I'll wait and see if I can find a how to write up or video. Not in a rush to break my car lol
You removed all 6 bolts?? It's not hard to take off once all the bolts are out, comes off easily by hand. Use a new gasket when you put it back on.
Wasn't aware I'd nee a new gasket. I did take out all 6 bolts and it was still in there pretty secure. I better see about getting a new gasket before I start. Thanks!
Yeah once the gasket is compressed initially and heated by the engine it's not likely to fully seal again if the seal is broken, then you'll likely end up randomly throwing lean codes.
Discussion Starter #7
So I picked up a new gasket and tossed my spacer in. Boy was it a lot easier than I thought!
I now have all the Overkill mods under the hood. Now to take it out and enjoy it!
Discussion Starter #11
Awesome!!! Thank you for the picks. How are you liking your new mods?
Love em! It's been about 2 years since I put them on and no problems.
Sent from my SM-N950U using Tapatalk
I'm in the process of installing the JacFab Spacer and I can't get the short bolt to screw in no matter what hole I try. Did you have this problem? Why would JacFab send you 5 long bolts and 1 short bolt when it looks like you need all 6 bolts to be long? Am I making sense?:eek:
1 - 12 of 12 Posts
