1 - 11 of 11 Posts
Just took out my intake box out because i was curious to see the condition of it with 35k miles.
What do you guys think? Does it need cleaning
  1. 2016 impala V6
    162425
    162426
It looks somewhat dirty - I would use spray throttle body cleaner (with the engine off and rags / paper towels under the bore opening) to clean it. Do not move the butterfly valve with your finger or a tool. Gunk builds-up on the edge of the valve, and in a circle around it on the bore. It can restrict airflow at idle, causing a rough idle.
^+1. It's best/easiest/safest to just remove it and give it a thorough front/back cleaning. I like the CRC tb spray in the red can. Available at parts stores and/or Wallyworld.
Hello, just saw this thread. Just seeinh if you guys may have some advice. I have a 2014 Impala 9th gen ltz 58k. If i take the throttle body all tbe way out and disconnect will it throw codes etc when i plug it back in? How do you clean throttle body without moving plate? Or is it ok to move?
Thank you for any and all help...very much appreciated
Either remove it to clean or have a friend depress the accelerator pedal to open while you clean underhood. No codes should be triggered if r&r'd.
Thank you so much for replying! The only way i see this possible is with the vehicle on. Is that how? Sorry of making it harder than it is...just worried lol. 1st newer car ever lol
May have to have the key in the on/run position, engine off? Try it 1st with the key out. I personally wouldn't worry about torque values, just install with a 1/4" ratchet, extension and socket. I've even used a nutdriver and socket.
I tried to just hit the start button once and only the radio and push brake to start comes on. I inserted the key for in the arm rest and same thing happens. Its wierd that no needles move or even turn on when i hit the accessories. Do you think there is a setting i have turned off?
1 - 11 of 11 Posts
