Good Evening,
I have just recently bought a 2016 LT Chevy Impala with dim intor lighting seems just from age. I've changed out the Vanity lights and center counsel lights but I can't figure out FOR THE LIFE OF ME how to change out the Map and Dome lights.
Any help would be greatly appreciated 馃檹
Thanks in advance
Map lights you remove lens cover with small screw drive/pick type tool..carefully pry and lens pops off.
Bulbs require finesse...very very carefully grab bulb glass with small needle nose pliers..just enough pressure to hold glass without breaking it...then firmly pull straight down/out slightly wiggling side to side.
This is from my experience with my 2012..with 194 type Bulbs..I'm assuming urs are the same
Thanks for the information i appreciate it.
After finally buying some interor tools to open it up come to find out the dome and map lights in the 16 Impala are on a circuit board and no way to change out just the bulb. The whole board would have to be replaced.
