I have a 2014 impala LTZ and wanted to know if the KN filter fits in the car, I am getting different answer if it fits or not, I look up the model number and it says fits 2013 and 2014, when I look at both engines, shows the intake in a different place but their are both 3.6. Can someone help me on this?
Might be the"old style" impala that you are seeing. Technically, a 2014 Impala could be the old-style (Impala Limited is the technical name). That is going to cause a lot of confusion going forward! They should have changed the name of the old-style Impala starting in 2014 to something else to avoid confusion.
I'm assuming that the engine compartment on the 2014 is very different from the 2012/2013/2014 "old-style" Impala, even though it's basically the same motor (3.6L)...
I believe so as well, I didn't wanted to buy it knowing that it doesn't fit and then go through the process of sending it back.
