2001 impala 3.8Ok here it goes. Coolant is filled and air bleed out. The car does not overheat at all. The temp gauge when cold the needle is all the way down way low than it should be I'm pretty sure. Then goes up once it starts to warm I changed the temp sensor and thermostat and all still same. When I unplug the temp sensor the fans do kick on.
Why am I not overheating if the fans dont work. I havent checked relays or fuses yet.
