how many liters will I need for changing transmission fluid in my chevy impala 2018 2.5L
there is not mentined in manual
Thanks
Thanks
The vehicle has the six-speed automatic transmission. A simply partial drain of fluid, when removing the drain plug, allows about 5 to 5 1/2 quarts of fluid to drain. You will have to convert to liters.
The transmission filter and all of the fluid is not serviceable, unless the transmission is removed from the vehicle.
To drain and refill it’s important to measure how much comes out and put that much back in. Rockauto has a decent price in acdelco dex6 regular and synthetic. In my limited, I use synthetic. Haven’t noticed much difference but I feel it helps add to longevity. I get 4.5-5 qts. But I’m sure to measure it, into a 5qt oil container works well. I’ve marked where it was when full so I know where 5 is bc sometimes the fifth one isn’t marked.
Good luck 👍🏻
