ok i truned my car off and now it will not start back up took it to a meachanic and they cant figure it out, so can u help me out. ? What do you think the problem might be?
do a fuel pump pressure test,to make sure it is getting enough fuel,make sure the plugs is getting a good spark,is the starter turning the motor over fast enough,you could also check FOR a bad sensor.good luck
HI
I would NOT go back to that mechanic... That's there job to figure out whats wrong...
There are 3 things that a motor needs to run..
Air
fuel
spark
it has to not have one or more of those to not run. A simple test should provide that info...
we know its getting air,
is it getting spark at the plugs ( pull a wire off and put a screw driver in the end and hold it near a bolt and have someone crank the motor does it spark.. if so then that's OK..
is it getting fuel.
good luck
tim
There is an immobiliser on these cars from what I understand, if the battery went bad, or disconeccted that could have told the ECU that something was wrong and will not allow the car to start until it is reset.
