Guest
·The problem i have is eveytime i want to start the car the starter clicks. The starter is new, and it did the same thing with the old starter. The engine has a very good ground the ignition switch is working perfectly. So the only way i could turn the engine on is by going from the starter switch directly to the positive post of the battery bypassing the ignition switch. What can be the problem with my wiring ?
