Guest
·i wanted to know if my car will raise up a bit more once i add 24" wheels on it? cause right now its sittin on stock 15"...
yes your car will raise up. u have a 15" wheel on there thats giving u car a lift of 15". when u put a 24 on it will be raised up 24 inches plus however big your tire is.i wanted to know if my car will raise up a bit more once i add 24" wheels on it? cause right now its sittin on stock 15"...
exactly what he said i.e. 22 inch rims u would be 11 1/2 inches or so of the ground depnding on tire size:biggrin:Not really....only half that height is "under the axle, so-to-speak...
The car doesn't "sit" on top of the whole 15 inches of wheel (not even regarding the tire itself).
And to the OP, of course your car will be raised up...how much you say?
Well, it depends on what suspension mods you have done or will do, etc., as well as the height of the tires you'll be using.
It's hard to throw a number with so many variables.
My suggestion would be to talk to a shop that has done this, or else someone with experience on the matter.
To throw for example, a 22" wheel on a vehicle does not mean said vehicle will now be 22 inches higher off the ground...:wink:
