some of the older GPs had issues w/ the 16" wheels clearing the calipers w/o rubbing, I run a set of PreGen GTP 16x8s of a 96 IIRC, the biggest issue you will run into is if the disc is smaller on the 95 then the Imp, if so they may rub. The BP and offset should be the same, but you'd have to tect mount them to see if they work ok or not
