...Any ideas? When at low RPM, it will cut out when I push the accelorater more and when it gets up into the higher RPM's, it will cut out too. It's only in a small power band that it will run normal. Thanks for any help.
From what you are saying there seems to be a problem with the air/fuel intake. You should check all your hoses and make sure they are hooked up, for instance if your MAP sensor is not hooked up to your intake this can happen.
