one of the 2 elements is burned change the bulb, that is why the light works and not the signal if your other bilnkers work then your flasher is good
Are both your front and rear bulbs burning? If both are not good bulbs then the remaining bulb will not blink. Otherwise check for the signal stat under the dash. Good Luck!
If both are on it's probably the flasher unit.Check both to be sure. Usually if the turn signal stays on it is because one of the bulbs has a burned filament or you have a bad ground.It takes a certain amount of voltage to make the flasher work properly, if that is "off" somehow it won't work right.
