ive tried a different stereo (had to have that unlocked),a different amp,a different onstar box,and still nothing
Well, apparently your wiring's screwed up somewhere, or you have a blown fuse. You'll have to get it fixed to get any sound.
First, is this the STOCK stereo & On Star system?
If its a Aftermarket than the stereo is not wired the right way.
The speakers may have a preamp at each speaker. Look inside of the trunk where the speakers are mounted. You should see a little black box mounted with-in the speaker housing.
If its there>> this cars stereo system had to be rewired to Bypass the preamps before the speakers will play.
If this is the Stock System it is the stereo and On Star box. They are chiped with a security code that will not allow it to work with other vehicle even if its from the same type and year of car you will have to go to the Dealership and purchase a factory stereo system and have them install it.
And for that amount of money you can get a high end CD-player with GPS that will operate in junction with the factory ON Star system.
