...jumpingwhat could it be? i have changed the cv axil, cross arm bushings ,top motor mounts,and checked the bottom motor and trasmission mounts both good. i have rotated the tires and nothing seems to stop the jumping or shaking on the right side.and my lug nuts are tight.
Your should check your struts and springs. Is the tire ware worse on that tire then the others? Possible alignment. It would be good to check and might be associated with your problem, giving you a clue. but if you checked everything else and NOT the springs or struts....Those could very well make your car jump like it does.
