...in it before it start to pull.? when it is in drive i have to get it up to 2000 rpm's before it starts to pull reverse is strong, and once it start to going it will not change out of gear.
tv cable
i would start by checking the fluid, then check your throttle valve cable.it can be adjusted by pressing the button in and then slide then center plastic sleeve back flush w/ the housing.let the button go.then take the throttle lever to wide open throttle,,,of course all this with the engine OFF.
