The car is trying to start but won't. My battery is new. Could it be my starter or fuel pump.
If it's turning over it's not your starter. Could be fuel pump, you would have to get a pressure gauge to test it or try spraying some starter fluid into the intake and see if it tries to start, if so, that could be your first indication that it is fuel related.
When you put the key in the "on" position, can you hear the fuel pump priming? If your caprice is lt1 equiped, you can also jump the fuel pump with a wire from the battery to the fuel pump test lead located on the passenger side of the engine compartment, near the A/C compressor.
