but i wont to replace it with a 1994 LT1 5.7L
or with a 350 5.7 vortec engine so wat changes will i have to make in order to make these changes?
why do you want to spend any money at all on a 14 year old thing like that???? That car is probably only worth about 300-500 dollars tops and another engine installed will be much more than that......have a tow truck take it away and save your money.......
Well, you're partially right, here. In that it is a Throttle Body Injection(TBI). But, unless it is a 9C1(police packaged)Caprice. It only came stock w/ a 305ci.
As far as the swap over to a 5.7L LT1. You'll need to acquire the computer(EPROM/ECM) for the LT1 as well as the tranny out of the donor car. I'm not sure if the 4L60(w/o the 'E') will bolt up to the LT1 w/o some kind of adapter. Plus, the donor LT1(4L60E) tranny will also, work better w/ the EPROM/ECM.
There use to be a couple of GREAT b-body web sites out there by Rob Creek. But, I haven't been able to access 'em in the last few months. Now, we are just kind of convined to the NAISSO(Nat'l Impala SS Owners Association) site. Or you can try some of the links listed( like <http://www.theherd.com/ > OR <http://www.regionofdoom.com/ >) on the NAISSO for some more info.
Good luck!
