problems with the suspenion? also seems to be setting very low in front end is this normal
With the car being that old, I'm sure it's time for a front end rebuild. I would go with Moog parts for that car. You can pick them up at any O'Reillys. Here is a list of parts and part numbers:
Tie rod, outer (2 per car) Moog ES2019RLT
Tie rod, inner (2 per car) Moog ES2020RLT
Sleeve, tie rod adjuster (2 per car) Moog ES2004S
Center link (relay rod) (1 per car) Moog DS1405
Idler arm (1 per car) Moog K6187T
Ball joint, upper (2 per car) Moog K5208
Ball joint, lower, 9/16" (2 per car) Moog K6145T
Shaft, upper arm, offset, with bushings (2 per car) Moog K6210
Bushing, front upper control arm (4 per car, included with shaft kit above) Moog K6409
Bushing, front lower control arm, forward (2 per car) Moog K6419
Bushing, front lower control arm, aft (2 per car) Moog K6419
Bushing, upper control arm, rear (to axle)(2 per car) Moog K6111(Moog is kit of 2 per arm = 1 of this item and 1 of item below)
Bushing, upper control arm, rear (to frame) (2 per car) Moog K6111(Moog is kit of 2 per arm = 1 of this item and 1 of item above)
Bushing, lower control arm, rear (4 per car) Moog K6116(Moog is kit of 2 per arm)
The parts below probably can be ordered at O'Reillys. If not, then AutoZone can order them:
Bump Stop (2 per car) Energy Suspension 9.9101
Sway Bar Links (2 per car) Energy Suspension 9.8123
Body Bushings Energy Suspension 3.5183
Front Sway Bar Frame Bushings (2 per car) Energy Suspension 3.5183
Rear Upper Coil Spring Isolator Set (2 per car) Energy Suspension 3.6110
The last two items are more of a preference/what your want the car to do type of options:
Springs: http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=16;t=004413
Shocks: http://impalassforum.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=16;t=004630
Good Luck
