1 - 8 of 8 Posts
Can someone give me instructions on how to replace a starter on a 2007 impala ss? Any diagrams, links, or pictures would help
Sent from my ADR6425LVW using AutoGuide.Com Free App
Storm Trooper Ralf
Should be easy like any other starter. Disconnect the battery,remove the cables from the terminals on the starter, two starter bolts and remove and replace in reverse order.
That's a 3.5 lol he has the 5.3 SS, but a good vid regardless
Oh well :lol: get the wrenches
Starter Motor Replacement (RPOs LZE/LZ4/LZ8)
1. Disconnect the negative battery cable.
2.Remove the front lower air deflector panel.
3.Remove the torque converter cover.
4.Remove the starter solenoid BAT terminal nut from the starter motor.
5.Remove the positive battery cable terminal and engine harness terminal from the starter.
6.Disconnect the starter motor electrical connector.
7.Remove the starter bolts.
8.Remove the starter.
Now to install
1.Position the starter motor to the engine.
2.Install the starter bolts. Torque them to 32 lb ft lbs.
3.Connect the starter motor electrical connector .
4.Install the engine harness terminal and positive battery cable terminal to the starter. Ensure that the positive battery cable terminal anti-rotation feature is aligned correctly.
5.Install the starter solenoid BAT terminal nut to the starter motor, tighten to (Note) 89 lb in lbs.
6.Install the torque converter cover.
7.Install the front lower air deflector panel.
8.Connect the negative battery cable.
Sounds easy on paper, but space is limited...
so glad I have an LT1. It's not that easy, but it's probably easier than what you're doing and definitely easier than replacing the cuda's starter...
1 - 8 of 8 Posts
