if you need to get the backseats out of the car, you will need a torx tip socket. ffirst you will need to move the frons seats up and get on your knees on the floorboard of the backseat facing the back of the car. push the front of the bottom of the backseat with your knees about 4 or 5 inches and then push up. do this on both the left and right sides. you will release the bottom part of the seat and it will just pull up and then come out. then locate the two shoulder belt bolts below the top part of the back seat on the left and right side. use the trox tip socket to take the bolt out, and that will release the bottom of the seat. all you will need to do then is lift up the bottom of the seat on eaither side, and it will come out. remember that you will need to tourqe the seat belt bolts back to factory specs when you put them back together, or whoever is in the backseat if you have and accident risks having a broken seatbelt.
