How to remove rear seat cushions
1 reading
23K views 1 reply 2 participants last post by  plano-doug
#1 ·
Do anyone know how to remove the rear seat cushion? Just so happens I left my rear window cracked and we had a VERY bad storm. I had my car in the garage overnight with two big fans blowing through the car but I want to remove the seat cushions and make sure all the moisture is gone from all area.
Thanks in advance
#2 ·
Every rear seat (lower) I've ever dealt with came out the same way. The best way to do it is to move the front seats all the way forward to clear out the foot space in the rear. Then get in the car, on the floor, facing aft, and push the seat rearward, then lift it up.
There are two catches, one on each side, that hold the seat in. If you look under the front edge of the seat - use a flashlight - you can see the catch mechanism. That will give you a better idea of what you're feeling when you start pushing and lifting.
HTH.
